Not all values returning when Symbolizing using Arcade Expression
961
06-11-2019 12:24 PM
NathanKoski
I have a map on ArcGIS Online of customer calls and I want to symbolize them into three categories:
  • Affected, No Call
  • Called, No Information
  • Called, Left Comments
I am using this arcade expression:
var comments = $feature.CALL_COMMENTS
return When(IsEmpty(comments), 'Affected, No Call',
                     comments == 'None','Called, No Information',
                     'Called, Left Comments');
But for some reason, if the value for 'Called, Left Comments' is never appearing on the map, instead those customers are grouped into "Other." Even though in the symbology panel "Other" has a count of Zero.
I have also tried:
If (IsEmpty(comments)){
   return 'Affected, No Call';
Else If (comments == 'None'){
   return 'Called, No Information';
Else {
   return 'Called, Left Comments';
Which results in the same.
And if I switch it around and do:
                     comments != 'None', 'Called, Left Comments'',
Then the default value returns if $feature.CALL_COMMENTS is None, but nothing is returned if $feature.CALL_COMMENTS is not equal null or 'None'
Does anyone know why this might be happening?
Thanks!
NathanKoski
Not really sure how or why, but it suddenly works after saving and refreshing the page for the 3rd or 4th time.
The symbology panel/tool must not be automatically refreshing the available data, even after data is edited or changed, and even with a refresh interval of 1-minute set.
