Hide the thousands separator in AGOL
2408
7
03-30-2017 12:32 PM
JoseSanchez
Occasional Contributor III
Hello everyone,
When showing a numeric value in a Web Map in AGOL how can I hide the thousands separator.
Thanks
KenBuja
MVP Esteemed Contributor
You'll have to configure the popup for the layer to do this (click the three dots ["More Options"]). Click the Configure Attributes option and select the field. You'll see the option "Use 1000 Separator". This will affect both the popup and the table view of the data.
KenBuja
RobertScheitlin__GISP
Jose,
   Hide it in what? The popup?
JoseSanchez
Hello again,
After unchecking the "Use 1000  Separator", it was removed from the "identity" popup window,  but  still shows on the "Label features" or label of the polygon in the  map, and in the editor  .
JeffBaker2
New Contributor III
In Manage Labels, switch to Arcade, no special formatting needed.  Simply identify the field to be labeled.  This will get rid of the 1000 separator in your labels.
JohannaKraus2
How do you get to arcade to change the labels, I don't see the option.
JohannaKraus2
never mind, I found it!
wayfaringrob
Hm, this doesn't seem to apply to tables in Experience Builder.
