Sweet for ArcGIS - zoom/pan to next feature
76
yesterday
JoeNunn
I am new to using Sweet for ArcGIS Builder to develop an app to check on many existing features, and am looking for a way to create a shortcut which can zoom to the next feature from a layer (that has not been reviewed yet).  The purpose is to make it as fast as possible to navigate to the next item that has not been checked.  I have a field with an 'unchecked' attribute so would ideally skip to next feature with that on it. I would also like to be able to filter the list of features based on an attribute eg Local Authority. If one of the existing templates has this already setup i can copy how it has been done.
Open to alternative ideas if this is not viable (i am aware there is no view of a table in Sweet).
Any help would be appreciated!
Thanks
Joe
Tags (1)
TimWestern
MVP
Sweet? Suite?   When you say builder do you mean WebAppBuilder?  Or do you mean the newer ExperienceBuilder?  Or some other Builder?
If its EXB, I'd ask what widgets have you tried?
Have you tried the query widget for example?
JoeNunn
Sadly not EXB - we are testing Sweet for ArcGIS due to its ability to use topology rules, which are not possible in Expereince Builder : https://www.esriuk.com/en-gb/arcgis/products/sweet-for-arcgis/overview
It does mean it limits some of the capabilities of Map viewer though, for example i havent found a means to view attribute tables in it.
