Immediate attribute update after Arcade-triggered ID generation in Sweet for ArcGIS
164
3 weeks ago
Rune_Van_Severen
When adding or splitting a polygon in Sweet for ArcGIS, I want a unique ID to be generated automatically in the background.
This is done using an Arcade trigger that reads and updates a sequence table added to the web map. The trigger logic works correctly: a new unique ID is generated and stored.
However, the behavior is currently the following:
  • The Arcade trigger runs successfully on add or split
  • The unique ID is created, but
  • The ID does not immediately appear in the feature’s attributes
  • The attribute value only becomes visible after a manual refresh
Question:
Is there a way in Sweet for ArcGIS to apply the generated ID immediately to the feature attributes, without requiring a refresh?
Why this matters:
  • Editors expect the ID to be available instantly after create or split
  • Manual refresh breaks the editing flow
Looking for:
  • A way to force an immediate attribute update after the Arcade trigger
  • Or confirmation whether this is a technical limitation of the current editing workflow
Any insights into whether this can be handled client-side, via configuration, or via a different trigger approach would be greatly appreciated.
