How to add ESRI widgets like print,sketch in contentpane in dojo and not in map view
687
06-05-2020 10:35 AM
upanshuvaid
Hi ,
How can i add esri arc gis js 4.15 widgets like print , sketch not in the map view but in the content pane of dojo which is created as tab in tab container .#add esri widgets in dojo
RobertScheitlin__GISP
This sample shows how to put a widget inside a side panel. You should use this an a starting point for what you want to achieve.
https://developers.arcgis.com/javascript/latest/sample-code/sandbox/index.html?sample=widgets-featur...
