Customization of a Dashboard Gauge (min, max, and guides)
667
02-26-2025 01:08 PM
sandra555
I have a feature layer with one row for each location. I have a dashboard with a map that is used for selecting a location. What I want to do is:
- Add a Gauge (Meter) to my dashboard
-set up 5 guides
-pull the Maximum, Minimum, and the From and To of the 5 Guides from fields in the feature layer associated with the selected location (so they change dynamically with the selected feature)
Is this possible? or must they be fixed values?
Thanks in advance.
sandra555
I ended up using a pie chart instead of a gauge. This worked well if I did not show the hover tips or the labels. Instead, I used a list element to create a custom legend. Example is provided in the attached screenshot. There are actually three pieces for each section and these can be set to fields in the layer. It would be nice if custom hover tips and labels were supported.
