I've had a longstanding need to visualize, query, and filter features using values from a related table, and came up with the following solution, which works great for my use case.
The use case involves managing stormwater catch basin inspection and cleaning (I've simplified the workflow for purposes of this post). The customer wanted field workers to be able to open Collector and quickly see basins that need attention or haven't been inspected/cleaned in over a year, and provide that same information in a dashboard.
It's very easy to set up:
Details on each step above:
from arcgis import GIS
from arcgis.features import FeatureLayer
import pandas as pd
from arcgis.features import SpatialDataFrame
from datetime import datetime, timedelta
import time
gis = GIS(f"https://someorg.maps.arcgis.com", 'someuser', 'somepass')
def update_basins():
one_day = datetime.today() - timedelta(days=1)
string_day = one_day.strftime('%Y-%m-%d %H:%M:%S')
where_query = f"DateInspected >= DATE '{string_day}'"
catch_basins = gis.content.get('21343f6579b74cf212576e5614db8866')
catch_basins_lyr = catch_basins.layers[0]
catch_basins_sdf = SpatialDataFrame.from_layer(catch_basins_lyr)
catch_basins_fset = catch_basins_lyr.query()
catch_basins_features = catch_basins_fset.features
cleanings_url = 'https://services9.arcgis.com/iERASXD4kaw1L6en/arcgis/rest/services/this_is_an_example/FeatureServer/1'
cleanings_lyr = FeatureLayer(cleanings_url)
cleanings_sdf = SpatialDataFrame.from_layer(cleanings_lyr)
cleanings_fset = cleanings_lyr.query(where=where_query, out_fields='DateInspected, FacilityID, Status')
cleanings_features = cleanings_fset.features
df=cleanings_sdf.sort_values('DateInspected', ascending=False)
df=df.drop_duplicates(subset="FacilityID")
overlap_rows = pd.merge(left = catch_basins_sdf, right = df, how='inner', on = 'FacilityID')
catch_basin_features = catch_basins_fset.features
cleaning_updates = cleanings_fset.features
cleaning_updates.reverse()
def update(basins, cleanings):
for FacilityID in overlap_rows['FacilityID']:
try:
basin_feature = [f for f in catch_basin_features if f.attributes['FacilityID'] == FacilityID][0]
cleaning_feature = [f for f in cleanings_features if f.attributes['FacilityID'] == FacilityID][0]
basin_feature.attributes['LastCleaning'] = cleaning_feature.attributes['DateInspected']
basin_feature.attributes['Status'] = cleaning_feature.attributes['Status']
catch_basins_lyr.edit_features(updates=[basin_feature])
print(f"Updated {basin_feature.attributes['FacilityID']} status to {basin_feature.attributes['Status']}", flush=True)
except:
continue
update(catch_basins_features, cleaning_updates)
while True:
update_basins()
time.sleep(60)
var present = Now()
var last_cleaning = $feature.LastCleaning
var cleaning_age = DateDiff(present, last_cleaning, 'years');
If (cleaning_age < 1 && $feature.Status == 'CleaningComplete') {
return "Current"
} else if ($feature.Status == 'NeedsAttention') {
return "Needs Attention"
} else if (cleaning_age > 1) {
return "Expired"
} else if (IsEmpty($feature.Status)) {
return "Record missing or incomplete"
I hope this is helpful to someone. Feel free to offer suggestions or ask questions. Hang in there everyone!
