Rename Files
239
11-18-2019 10:51 AM
MichaelKellyTeck
It doesn't appear like it is possible to rename Files that you have uploaded to a Notebook. This is functionality that I think would be useful. Right now you have options to select a file and delete. If there were another button for renaming a file it would make the user experience a little better. The current workaround is to download the file, rename locally and upload again which seems a little clunky.
MichaelKellyTeck
Also having an option to create a folder via the UI would be useful.
ShannonKalisky
Hi Michael,
You can rename files using Python:
Original File Name:
Original File Name
Rname the file using:
import os
dataset = 'Path/Name_of_original' (just clicking the plus sign next to the original file will automatically insert this snippet).
os.rename (dataset, 'Path/new_name'
Renamed File
You will need to refresh your Files TOC (navigate up to /arcgis and back to /arcgis/home) to see the changed file name.
Hope that helps!
Shannon
