Values shifting to different fields in attribute table
1990
05-04-2011 03:11 AM
SharonSchulte
New Contributor II
I use ArcGIS 10 and I recently installed Business Analyst, version 10. I'm mentioning that because I've been using 10 for about 7-8 months and haven't had any issues. When I opened a version of our street file to do normal editing, the values shifted fields. I went to a new mxd, pulled in the streets again, and the same thing happened, tried viewing our production streets, and the same thing. Please see attached. Where joinid is it's showing the network_road_type and it should just be a number, sfeanme should be the street name and it has a the class field. Is there a bug w/BA? Any help would be greatly appreciated. I'm considering removing the BA extension to see if that's the problems.
Thanks
Sharon Schulte
Also, when I checked with others who also have BA installed, they see the same scrambling I see.
JamesSimard1
New Contributor III
I found the solution/ work-around. You must save the file as a shapefile instead of a geodatabase feature class. For some reason it messes up when it remains in a GB format.
Thanks
Sharon Schulte
