Utility Network analyst: Similar tasks!
3771
11-08-2011 12:52 AM
JamalNUMAN
Legendary Contributor
I'm not sure about the critical difference between:
I) path tasks:
1.Find path upstream
2. Find path
II) upstream tasks:
1. Find path upstream
2. Find upstream accumulation
3. Trace upstream
III) Trace and Find:
1. Trace upstream
2. Find path upstream
thank you in advance,
regards
Jamal
Jamal Numan
RobertBorchert
Honored Contributor
I) path tasks:
1.Find path upstream   You place a flag and it finds the direct path to the SOURCE using weights
2. Find path   You place two flags and it finds the direct path between the two flags using weights
II) upstream tasks:  FIND Paths will use any weights you have built into your Geometric Network.  Trace will simply find the most direct route.
3. Trace upstream
III) Trace and Find:  Same answer.  Trace finds the most direct route, FIND uses the path of least resistance.
1. Trace upstream
JamalNUMAN
I) path tasks:
3. Trace upstream
1. Trace upstream
Many thanks Robert. this really helps
I'm not sure if I'm right when i say that the whole idea behind the geometric network and then the "Utility network analyst" is just to have 3 main tasks:
- up/downstream
- connected/disconnected
- loops
is that all the power that the "Utility network analyst" has?
does this satisfy all the needs of the end-user?
even with the add-in features, they are not of that super power!
regards
Jamal
Jamal Numan
RobertBorchert
Honored Contributor
I suppose it depends on how you are going to use the GM.  I work for an electric utility.  for us it is essential that we have things linked together correctly from Substation to Meter.  We use it to make sure the are no loops, (meaning a short circuit where the electricity loops back on itself).
We need 100% connectivity in order to export features to WindMil for load management purposes.  If you wish to use the GM for routing you need it intact.
Also, we use it for analysis in load management to determine how many miles of conductor we have of each phase.  we can  use it to determine the  number and size of transformers on a particular section of line.  Also it can be used as a basic outage management tool.  You place a flag on each customer that calls in an outage and do Find Common ancestors and have it only search for sectionalizing devices.
If you have built yours with weights you can use find upstream accumulation to determine the resistance to the destination
I) path tasks:
3. Trace upstream
1. Trace upstream
JamalNUMAN
Thank you Robert for the elaboration. this is quite useful.
I got from your notes the power of using the "Weight" in the analysis.
1) i tried to create a weight to represent the length of the pipes such that the cost can indicate the distance from the flag to the source but sounds to not work properly!
2) why we have two weights (along/against the digitized direction) for the edge considering that the flow is one-direction based?
3) if your time permits, please, consider the attached screenshots and a sample of my database, how can i create a weight to reflects and calculates the length of the pipe from a flag to the source?
appreciated,
Jamal
Jamal Numan
