Trying to incorporate a GTFS route sequence into service area analysis layer
647
11-15-2010 02:01 PM
AndrewJoseph
Hello all,
I am working on a research project that looks at the maximum distance a person can travel by bus from a given intersection within one hour at specified time intervals, such as 4:00 PM.
To do this I have created a route shapefile and stop points from the GTFS (Google or General Transit Feed Specification) data
For each stop on each trip along each route I have the arrival time and departure times of the buses, which I have standardized into impedances by calculating the hours elapsed since the beginning of the interval. My problem is that I am unsure of how to restrict transfers to trips that have not already occured (i.e. the total accumulated time impedance < departure time of trip) and then how to make the solver adhere to the trip sequences once a transfer has occured.
This problem has been stumping me all week; any help would be greatly appreciated!
Andrew
JaySandhu
Service Area finds the area upto a specified break value from one or more locations.
You say:
"My problem is that I am unsure of how to restrict transfers to trips that have not already occured (i.e. the total accumulated time impedance < departure time of trip) and then how to make the solver adhere to the trip sequences once a transfer has occured."
I have tried to understand what this means but cannot. If you want to explain it more perhaps someone can provide a way to solve it.
As far as:
"I am working on a research project that looks at the maximum distance a person can travel by bus from a given intersection within one hour at specified time intervals, such as 4:00 PM."
If you take a look at the Network Analyst tutorial data, the Paris dataset has a pedestrian walk time attribute that lets you model the travel on metro plus walk on roads. You can solve a service area on that data from any location and see how far you can get for a given break value. Is this what you are trying to achieve? The dataset is used in the following tutorial:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Exercise_5_Calculating_service_areas_a...
Regards,
Jay Sandhu
AndrewJoseph
I'm sorry for not properly explaining the problem, I have attached a pdf in two zip files that addresses the topic in greater depth.
http://help.arcgis.com/en/arcgisdesk...0000060000000/
I have worked through that tutorial already trying to solve this problem and have unfortunately found that my problem is more complex than the topics discussed in the tutorial.
Andrew
MichaelLachman1
Bump.  Andrew, were you ever able to figure out a solution to this problem?  I'm working on a similar study, though not using a GTFS feed as the source.
MelindaMorang1
New Contributor III
Hi everyone.  I've been working on this exact same problem and have developed a tool that allows you to calculate walking/transit service areas using Network Analyst and GTFS data.  Check out http://transit.melindamorang.com.  A beta version of the tool will be available for download within the next few weeks, and I'd love to get your feedback and ideas for improvement.
MelindaMorang
Hello everyone.  I just wanted to let you know about a new prototype tool from Esri's Network Analyst team which allows you to add GTFS public transit data directly to a network dataset.  You can use this network dataset with the Network Analyst tools to run time-aware analyses that incorporate the transit schedules.
You can download the toolset and instructions here:
http://www.arcgis.com/home/item.html?id=0fa52a75d9ba4abcad6b88bb6285fae1
Please do not hesitate to contact me at mmorang@esri.com with questions or comments about this toolset.
