Solve OD-matrix for distance, but add travel time to outputs
696
05-17-2017 05:53 PM
RogierBusscher
Hi everyone,
I have a bike network with two kinds of streets. The first are just regular streets, where a biker has a speed of 6km/h. The second type are dedicated bike lanes where a biker has a speed of 10km/h.
Now i would like to solve a closest facility problem with the network analyst. I would like to solve for closest distance, but I also would like to know the travel time that belongs to this closest distance.
Is there an easy way to do this?
Thank you in advance
AsafBen-Ari
Hi Rogier,
You can define everything you need in the Closest Facility's layer properties. In asumption that you created your network properly (with the required cost attributes), the impedence defined in the Analysis settings tab (meters, feet etc. in your case), and the other attributes that you like to get, in the Accumulation tab.
Regards,
Asaf.
RogierBusscher
Hi Asaf,
Thanks a lot!
Regards,
Roger
