select parts of route
573
09-08-2010 03:58 AM
MartinaRagettli
Is there a way to select PARTS of a route based on the network source? For example, I have routes which contain walking on a street and bus rides on the bus line network. I now want to select the sections where the routes overlap with the bus line network.
I would appreciate your help very much!
JaySandhu
Take a look at this resource to add the traversal result (every edge that makes up the path) and then use it to select the source edges you want.
http://help.arcgis.com/en/sdk/10.0/arcobjects_net/conceptualhelp/index.html#//000100000245000000
Jay Sandhu
