Optimum route for e-car according to battery capacity and charging point locations
575
04-08-2014 09:28 AM
FrancescoPilla
Hi all,
I'm trying to solve a problem which involves the calculation of the optimum route for e-car according to battery capacity and charging point locations using ArcGIS Network Analyst.
My datasets are the road network and the locations of the charging points.
I found a solution which involves the use of the Service Areas approach: I calculate distance buffers around the charging stations using as distance the number of miles that the e-car can travel with a fully charged battery, then I exclude the segments of road that are not included in the buffers and so on.
I was just wondering if there is a more refined way to solve this problem.
I'd greatly appreciate any feedback.
Francesco
JoeBorgione
Hi all,
Francesco
You can always refine your approach: how much time/$$ do you want to spend?
A fully charged e-car may not run as long at 55 mph versus 25 mph.  So maybe you should include speed limits as part of your model.  An e-car may not run as long up hill as it does down hill, so maybe z/elevation data might be useful.  And what about temperature?  Does an e-car run as long at 55 degrees f as it does at 25 degrees f?
That should just about do it....
FrancescoPilla
Hi Joe,
many thanks for your reply and suggestions!
I was wondering if there is a set of specific settings or tools that I can use to refine my analysis.
The way I'm doing it now requires a series of steps which also involves the trimming of the network, so I feel my approach is a bit clumsy.
F
JoeBorgione
Perhaps one of the ESRI guys can chime in...
Short answer is NA is a data and consequently labor intensive endeavor.
