OD Cost Matrix , Actual Route
320
22
07-30-2020 04:33 PM
MuhammadRamzan
New Contributor II
I have made a Multimodal network analysis consisting of Maritime_Routes, World_Railroads, and World_roads as a mode of transportation.
I have applied the OD cost matrix and that works fine. I have to find out how many countries the route between the two cities is passing.
I have applied the OD cost matrix, calculates the distance and draw a straight line, rather than the ACTUAL ROUTE.
Thanks
Reply
MelindaMorang
The option is on the Closest Facility ribbon.
MuhammadRamzan
New Contributor II
I have 2341 cities. so I will set this number to 2341. Right?
Reply
MelindaMorang
Yes
Reply
MuhammadRamzan
New Contributor II
HI
I am getting this message
"Warning: The output geometry for "Location 3 - Location 1" in "Routes" has no M values because the maximum M value is larger than the largest M value that can be supported by the M domain."
Reply
MelindaMorang
If you don't need M values, you can ignore this message.  M values are used primarily for linear referencing when you need to know the distance along a line that a point falls.
MuhammadRamzan
New Contributor II
Hi thanks
Is it possible to do the computation in Enterprise Geodatabase with ArcGIS Pro? As I have a large number of cities and it is taking to long.
What would be the process for that?
thanks
Reply
MelindaMorang
Yes, you can put your network dataset in your Enterprise Geodatabase, then set the network data source to point to that network dataset.  However, I don't think that would make the analysis any faster.
MuhammadRamzan
New Contributor II
Can you please refer me to any tutorial on this. thanks
Reply
MuhammadRamzan
New Contributor II
Hi Melinda Morang
Hi, is the network model tool available in ArcGIS online version?
Thanks
Reply
MelindaMorang
Can you clarify what you mean by "network model tool"?
Reply
