Network Dataset: Directions
1796
08-03-2016 11:29 AM
AndrePedrosa
I´ve created a Network Dataset but I can´t use directions. The Network Dataset is working well with arcgis extension Network Analyst but didn´t allow me to select the Directions after I created my route.
Below is my network and as you can see in the button "Directions" is asking me for a length atrribute that I already have
I would like to know if someone had a similiar problem or if someone sees some problem in my network.
Type: Geodatabase-Based Network Dataset
Version: 10.1
Sources:
  Edge Sources:
    Ferry_boat
    Streets
  Junction Sources:
    Entrance_Ferry
Turns:
  <Global Turns>
Connectivity:
  Group 1:
    Edge Connectivity:
      Streets (Any Vertex)
    Junction Connectivity - Transfer Groups {2}:
      Entrance_Ferry (Override) - Transfer Groups {2}
  Group 2:
    Edge Connectivity:
      Ferry_boat (Any Vertex)
    Junction Connectivity - Transfer Groups {1}:
      Entrance_Ferry (Override) - Transfer Groups {1}
Elevation Model: None
Attributes:
  Length:
    Usage Type: Cost
    Data Type: Double
    Units Type: Meters
    Use by Default: False
    Source Attribute Evaluators:
      Ferry_boat (From-To): Constant = 0
      Ferry_boat (To-From): Constant = 0
      Streets (From-To): Field
          Language: VBScript
          Expression: [Shape_Length]
      Streets (To-From): Field
          Language: VBScript
    Default Attribute Evaluators:
      Default Edges: Constant = 0
      Default Junctions: Constant = 0
      Default Turns: Constant = 0
  Time:
    Usage Type: Cost
    Data Type: Double
    Units Type: Minutes
      Ferry_boat (From-To): Constant = 15
      Ferry_boat (To-From): Constant = 15
          Language: VBScript
          Expression: [Tempo]
          Language: VBScript
          Expression: [Tempo]
  Cost:
    Usage Type: Cost
    Data Type: Double
    Units Type: Unknown
    Use by Default: True
          Language: VBScript
          Expression: [Total]
          Language: VBScript
          Expression: [Total]
Directions:
  Directions Ready: No
    -Length Attribute Required
Thank you very much.
Best Regards, Andre.
DanPatterson_Retired
Setting directions—Help | ArcGIS for Desktop the first 3 criteria are listed... check your table
Modifying direction settings—Help | ArcGIS for Desktop and check here
AndrePedrosa
Thank you very much. I found the problem, it was missing a text field in one of the shapefiles.
