I am fairly new to GIS, and have been using the Network Analyst to route from one city to another. The routing part is going fine, but when ArcMap gives me the driving distance, it is way off. For example, I routed from one city to another and got a driving distance of <0.1 mile. When I used the measure tool to measure the distance between the two cities in a straight line, I get 286 miles. The data is all using WGS 1984 coordinate system if that is of any use. Any help? Thanks.
You have to use the Project tool and project your decimal degree data to some planar coordinate system (ie UTM State Plane etc). The values you are getting are in decimal degrees which is what a WGS84 coordinate system uses.
