Is there a command to measure the distance from one point to many other points?
1475
08-13-2011 11:53 AM
by Anonymous User
Not applicable
Original User: Jamal432@gmail.com
please, see the attached images that shows my question
i need to measure the distance from the point (called Ramallah) to all other points and to have the answer in a table.
if the network between the points is given, then the the tool "OD Cost Matrix" in the "Network Analyst" can be used to get the distance, but in this case this network is not given.
then, how to measure the distance between the Ramallah point and all other points?
regards
Jamal
Reply
by Anonymous User
Not applicable
Original User: jborgion
Yes. Nearest
Reply
Occasional Contributor II
Reply
by Anonymous User
Not applicable
Have you tried Near ?
See the online help at http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00080000001q000000.htm
thank you for the answer Joe Borgione and raycarnes.
i got that the most appropriate tool to measure the distance is "Point distance"
regards
Jamal
Reply
Check in ArcTool box -> Analysis Tools the tools Near, Point distance, Generate Near Table
Reply
