public void LoadAnalysisObjectsByField(ESRI.ArcGIS.Geodatabase.ITable inputClass,
string naClassName, ESRI.ArcGIS.NetworkAnalyst.INAContext naContext)
// Both Initialize and Load take a cursor from the input class
ESRI.ArcGIS.Geodatabase.ICursor cursor = inputClass.Search(null, false)as
ESRI.ArcGIS.Geodatabase.ICursor;
ESRI.ArcGIS.NetworkAnalyst.INAClassLoader2 naClassLoader = new
ESRI.ArcGIS.NetworkAnalyst.NAClassLoaderClass();
naClassLoader.Initialize(naContext, naClassName, cursor);
// Store the current set of locator agents, so they can be added back later
int agentCount = naContext.Locator.LocatorAgentCount;
var listOfAgents = new System.Collections.Generic.List <
ESRI.ArcGIS.NetworkAnalyst.INALocatorAgent > ();
for (int locIndex = 0; locIndex < agentCount; locIndex++)
listOfAgents.Add(naContext.Locator.get_LocatorAgent(locIndex));
// Remove the existing locator agents from the locator
// This for loop is done in reverse order, because agents are being removed as the loop executes
for (int locIndex = agentCount - 1; locIndex >= 0; locIndex--)
naContext.Locator.RemoveLocatorAgent(locIndex);
// Create and add a fields agent
var fieldsAgent = new
ESRI.ArcGIS.NetworkAnalyst.NALocatorLocationFieldsAgentClass()as
ESRI.ArcGIS.NetworkAnalyst.INALocatorLocationFieldsAgent2;
// Set the field names appropriately based on input data and NAClass
var naClass = naContext.NAClasses.get_ItemByName(naClassName)as
ESRI.ArcGIS.NetworkAnalyst.INAClass;
var naFeatureClass = naClass as ESRI.ArcGIS.Geodatabase.IFeatureClass;
// Check to see if the NAClass is of type NALocation or NALocationRanges
ESRI.ArcGIS.esriSystem.UID naLocationFeatureUID = new
ESRI.ArcGIS.esriSystem.UIDClass();
naLocationFeatureUID.Value = "esriNetworkAnalyst.NALocationFeature";
ESRI.ArcGIS.esriSystem.UID naLocationFeatureRangesUID = new
naLocationFeatureRangesUID.Value = "esriNetworkAnalyst.NALocationRangesFeature";
if (naFeatureClass.CLSID.Compare(naLocationFeatureUID))
// The field names listed below are the names used in ArcGIS Network Analyst extension classes to represent NALocations.
// These are also the names of fields added by the CalculateLocations geoprocessing tool
fieldsAgent.OIDFieldName = "SourceOID";
fieldsAgent.SourceIDFieldName = "SourceID";
fieldsAgent.PositionFieldName = "PosAlong";
fieldsAgent.SideFieldName = "SideOfEdge";
else if (naFeatureClass.CLSID.Compare(naLocationFeatureRangesUID))
// The location ranges input field must be of type BLOB
fieldsAgent.LocationRangesFieldName = "Locations";
var blobField = inputClass.Fields.get_Field(inputClass.FindField
(fieldsAgent.LocationRangesFieldName));
if (blobField.Type !=
ESRI.ArcGIS.Geodatabase.esriFieldType.esriFieldTypeBlob)
System.Windows.Forms.MessageBox.Show(
"Loading location ranges by field requires a blob field");
return ;
naContext.Locator.AddLocatorAgent(fieldsAgent as
ESRI.ArcGIS.NetworkAnalyst.INALocatorAgent);
// After Loading is complete, the rowsIn and rowsLocated variable can be used to verify
// that every row from the input feature class has been loaded into the network analysis class
int rowsIn = 0;
int rowsLocated = 0;
naClassLoader.Load(cursor, null, ref rowsIn, ref rowsLocated);
// Now remove the custom fields agent and add back the stored agents
naContext.Locator.RemoveLocatorAgent(0);
foreach (var agent in listOfAgents)
naContext.Locator.AddLocatorAgent(agent);
public void LoadAnalysisObjectsByField(ESRI.ArcGIS.Geodatabase.ITable inputClass, string naClassName, ESRI.ArcGIS.NetworkAnalyst.INAContext naContext)
var fieldsAgent = new ESRI.ArcGIS.NetworkAnalyst.NALocatorLocationFieldsAgentClass() as ESRI.ArcGIS.NetworkAnalyst.INALocatorLocationFieldsAgent2;
var naClass = naContext.NAClasses.get_ItemByName(naClassName) as ESRI.ArcGIS.NetworkAnalyst.INAClass;
ESRI.ArcGIS.esriSystem.UID naLocationFeatureUID = new ESRI.ArcGIS.esriSystem.UIDClass();
ESRI.ArcGIS.esriSystem.UID naLocationFeatureRangesUID = new ESRI.ArcGIS.esriSystem.UIDClass();
// The field names listed below are the names used in Network Analyst classes to represent NALocations.
var blobField = inputClass.Fields.get_Field(inputClass.FindField(fieldsAgent.LocationRangesFieldName));
if (blobField.Type != ESRI.ArcGIS.Geodatabase.esriFieldType.esriFieldTypeBlob)
System.Windows.Forms.MessageBox.Show("Loading location ranges by field requires a blob field");
return;
// Bind for a fields agent will properly associate the agent with the network dataset.
// This is useful internally for mapping SourceID back to network sources.
((INALocatorAgent)fieldsAgent).Bind(naContext.NetworkDataset, null);
var posFieldsLocator = new ESRI.ArcGIS.NetworkAnalyst.NALocatorClass() as INALocator;
posFieldsLocator.FindClosestAmongAllAgents = false;
posFieldsLocator.SnapToleranceUnits = ESRI.ArcGIS.esriSystem.esriUnits.esriMeters;
posFieldsLocator.SnapTolerance = 0.0;
// Bind to network dataset is required. Bind has a side effect of adding feature locator agents for all
// feature sources. In this case we only want a field locator agent so remove the feature agents after Bind
// and before adding the field agent to NALocator.
posFieldsLocator.Bind(naContext.NetworkDataset, null);
int locatorAgentCount = posFieldsLocator.LocatorAgentCount;
for (int i = locatorAgentCount - 1; i >= 0; --i)
posFieldsLocator.RemoveLocatorAgent(i);
posFieldsLocator.AddLocatorAgent((INALocatorAgent)fieldsAgent);
((INAContextEdit)naContext).Locator = posFieldsLocator;
ESRI.ArcGIS.Geodatabase.ICursor cursor = inputClass.Search(null, false) as ESRI.ArcGIS.Geodatabase.ICursor;
ESRI.ArcGIS.NetworkAnalyst.INAClassLoader2 naClassLoader = new ESRI.ArcGIS.NetworkAnalyst.NAClassLoaderClass();
int rowsIn = 0;
// Now remove the custom fields agent and reset the locator
naContext.Locator.Bind(naContext.NetworkDataset, null);
