How to input exact time like 9:00:00 AM in attribute table
753
05-27-2023 10:16 AM
HninSandarLwin
Dear Sir,
I would like to ask questions regarding with adding timestart1 and timeend1 in attribute table for locations point shapefile.
I created point shapefile to add locations in network dataset and add field which is necessary for running vehicle routing problem. TimeStart1 and TimeEnd1 are added for Timewindow, however, I cannot add time in attribute.
The problem is I chose Date Data type before adding time. It just change to 12:00:00 AM even I added 9:00:00 AM in the field when I clicked "save edits".
The input time that I want to add is similar with the following table.
Therefore, I would like to know is how can I add time as shown in figure. I want to add 9:00:00 AM and 5:00:00 PM for TimeStart1 and TimeEnd1.
Thank you so much for your time.
Sincerely,
Hnin Sandar Lwin
DanPatterson
If you are using shapefiles...
Geoprocessing considerations for shapefile output—ArcGIS Pro | Documentation
Date fields only support date and do not support time.
Caution:
The nonsupport of time in date fields is a serious limitation for any tool that performs temporal analysis.
... sort of retired...
