Hi! all,
I hope I get some insight on this...
Given everything else constant, if a network does NOT have a hierarchy built, does the closest facility that gets picked gets picked on the basis of 'Restriction'?
I noticeed that a route was created for a closest facility in my network (without hierarchy) that veered from the feeder road (with restriction) for a short distance (along a small loop of minor road that is two way, and without restriction) only to continue on the feeder later. Feeder has higher speed while the minor road has lower speed. There is no connectivity problem nor there is a 'direction digitized' problem on the portion of route that was not chosen.
Thank You,
Shilpa
