Extract TOIDs from route
1676
09-20-2011 04:23 AM
JamesSmith5
Hi everyone,
I'm a bit of a newbie, but hope someone might be able to help me.
As an example of my problem, I have 10 origins and 10 destinations. I am using the Network Analyst toolbox and an ITN to come up with routes between each of them. However I have some 3rd party data that I would like to join to these routes. The identifying field in the 3rd party data is TOID. So is there some way to do this? When I look at the attribute table of the route that Arc has created, it does not seem to have a column containing the TOIDs of the roads that the route has used. Can these be accessed somehow, and then joined to my data?
Thanks
James
JamesSmith5
Just been having a proper glance through the Forum history and came accross this:
http://forums.arcgis.com/threads/37655-Finding-all-links-in-a-route
Seems to be a similar problem. Will read up on it and the answers Jay suggests, but in the meantime if anyone has any ideas that would be appreciated.
JaySandhu
I have replied to this in the other thread:
http://forums.arcgis.com/threads/37655-Finding-all-links-in-a-route?p=135000&posted=1#post135000
Basically use the traversal result addin from the ArcGIS resources to get to the table of all the edges traversed.
Jay Sandhu
JamesSmith5
Jay Sandhu
Dear Jay,
Thanks for the response. I have used the add-in as you suggest and now have 3 new tables; Edges, Turns and Junctions. Unfortunately none of these tables have brought through the field RoadLinkTOID, which is what I need to link to my external data. Is there someway for me to bring this through, or alternatively to link back from the Edges table to the Road_Links table (where the RoadLinkTOID is stored) ?
Thanks for your help!
James
JaySandhu
As I mentioned in my previous post, read the other other thread where I provided two ways to solve this including doing Joins.
Jay Sandhu
