Error in building network with turn features in ArcGIS 10.1
4038
12-02-2014 04:47 AM
yonatanrubinstein
I'm working on ArcGIS 10.1. I have a dataset with a streets layer and a turn table. I want to create a road network for calculating routes.
Problem: Every time I create the network and build it I get a lot of build errors of the same type:
SourceName: no_turn*,ObjectID: 5**, Cannot find edge element corresponding to turn identifier 1.
What is the problem?
(The data is valid - it was used to make a correct network in the past - I took the data from there and tried to make a new, identical network.)
* no_turn is the name of the turn table.
** 5 - the number of the objectid of the specific turn
BrookBrook
make sure the turn feature can find each edge which it  refers to ,Check if the feature class id have changed,
