Directions - "totalLength" units of measure?
1284
06-27-2014 06:46 AM
Sa_EdA_Rafat
New Contributor II
Hi all,
Does anyone know where the units-of-measure of the "totalLength" is specified?
This seems to be in meters even though my layer says it in Miles ("directionsLengthUnits": "esriNAUMiles").
json["directions"];
"routeId": 1,
"routeName": "Location 1 - Location 2",
"hasM": true,
"summary": {
"totalLength": 5221.98296067188,
"totalTime": 4.41884235246107,
"totalDriveTime": 4.4188423535129635,
"envelope": {
"xmin": -87.652578690999917,
"ymin": 41.878818755651714,
"xmax": -87.6294279999999,
"ymax": 41.903987605323444,
"spatialReference": {
"wkid": 4326,
"latestWkid": 4326
DanPatterson_Retired
Are you sure that NA does the conversion for you?  I think the units are in the units of the coordinate system, ergo, if the projection has metric units, then it should be in meters
Sa_EdA_Rafat
New Contributor II
I measured the distance - the value is in meters.
My data is in WGS84, is meters the default unit of measure (not decimal degrees)?
Firstly, if you are using the Network Analyst, you should be using projected data and not relying on projections-on-the-fly
Sa_EdA_Rafat
New Contributor II
Sorry, I don't understand your response!
I think I'm in the wrong forum... I'll repost this for Server.
