Creating a network dataset programmatically
2905
12-08-2014 12:37 AM
SmitaSathe
I am running into a problem with creating and building a network dataset programmatically. My feature dataset is hosted in an SDE database and I need to build a network dataset for it. I have version 10.2.1 installed. I have the following code to do it. I get an error at the very end of the function when CreateDataset is called:
Exception from HRESULT: 0x80040220
I got most of this code from the ESRI site and adapted it to my situation. I have not been able to figure out what the problem is. If someone could help me, I would be most obliged.
Thanks in advance....
Smita
        public static void CreateAndBuildNetworkDataset(IDatasetName datasetName)
            IFeatureClass featureClass;
            try
                // Create an empty data element for a buildable network dataset.
                IDENetworkDataset2 deNetworkDataset = new DENetworkDatasetClass();
                deNetworkDataset.Buildable = true;
                IDataset dataset = null;
                IFields iFields;
                OpenTableOrFeatureClass(datasetName, out iFields, out dataset);
                featureClass = dataset as IFeatureClass;
                IGeoDataset geoDataset = (IGeoDataset)dataset;
                // Copy the feature dataset's extent and spatial reference to the network dataset data element.
                IDEGeoDataset deGeoDataset = (IDEGeoDataset)deNetworkDataset;
                deGeoDataset.Extent = geoDataset.Extent;
                deGeoDataset.SpatialReference = geoDataset.SpatialReference;
                // Specify the name of the network dataset.
                IDataElement dataElement = (IDataElement)deNetworkDataset;
                dataElement.Name = string.Format("{0}_ND", datasetName.Name);
                //Specify network sources
                // Specify the network dataset's elevation model.
                deNetworkDataset.ElevationModel = esriNetworkElevationModel.esriNEMElevationFields;
                deNetworkDataset.NetworkType = esriNetworkDatasetType.esriNDTGeodatabase;
                // Create an EdgeFeatureSource object and point it to the Streets feature class.
                IEdgeFeatureSource streetsEdgeFeatureSource = new EdgeFeatureSourceClass();
                INetworkSource streetsNetworkSource = (INetworkSource)streetsEdgeFeatureSource;
                streetsNetworkSource.Name = dataset.Name;
                streetsNetworkSource.ElementType = esriNetworkElementType.esriNETEdge;
                // Set the edge feature source's connectivity settings.
                streetsEdgeFeatureSource.UsesSubtypes = false;
                streetsEdgeFeatureSource.ClassConnectivityGroup = 1;
                streetsEdgeFeatureSource.ClassConnectivityPolicy =
                    esriNetworkEdgeConnectivityPolicy.esriNECPEndVertex;
                streetsEdgeFeatureSource.FromElevationFieldName = "FromElevation";
                streetsEdgeFeatureSource.ToElevationFieldName = "ToElevation";
                //Specifying directions settings
                // Create a StreetNameFields object and populate its settings for the Streets source.
                IStreetNameFields streetNameFields = new StreetNameFieldsClass();
                streetNameFields.Priority = 1; // Priority 1 indicates the primary street name.
                streetNameFields.StreetNameFieldName = "StreetName";
                streetNameFields.PrefixTypeFieldName = "PrefixType";
                // Add the StreetNameFields object to a new NetworkSourceDirections object,
                // then add it to the EdgeFeatureSource object created earlier.
                INetworkSourceDirections streetNetworkSourceDirections = new
                    NetworkSourceDirectionsClass();
                IArray streetNameFieldsArray = new ArrayClass();
                streetNameFieldsArray.Add(streetNameFields);
                streetNetworkSourceDirections.StreetNameFields = streetNameFieldsArray;
                streetsNetworkSource.NetworkSourceDirections = streetNetworkSourceDirections;
                IArray sourceArray = new ArrayClass();
                sourceArray.Add(streetsNetworkSource);
                deNetworkDataset.Sources = sourceArray;
                //global turns
                deNetworkDataset.SupportsTurns = true;
                //Attributes
                IArray attributeArray = new ArrayClass();
                // Initialize variables reused when creating attributes.
                IEvaluatedNetworkAttribute evalNetAttr;
                INetworkAttribute2 netAttr2;
                INetworkFieldEvaluator netFieldEval;
                INetworkConstantEvaluator netConstEval;
                //Length field
                // Create an EvaluatedNetworkAttribute object and populate its settings.
                evalNetAttr = new EvaluatedNetworkAttributeClass();
                netAttr2 = (INetworkAttribute2)evalNetAttr;
                netAttr2.Name = "Length";
                netAttr2.UsageType = esriNetworkAttributeUsageType.esriNAUTCost;
                netAttr2.DataType = esriNetworkAttributeDataType.esriNADTDouble;
                netAttr2.Units = esriNetworkAttributeUnits.esriNAUMeters;
                netAttr2.UseByDefault = true;
                // Create evaluator objects and set them on the EvaluatedNetworkAttribute object.
                netFieldEval = new NetworkFieldEvaluatorClass();
                netFieldEval.SetExpression("[Shape]", "");
                //netFieldEval.SetExpression("[SpeedLimit]", "");
                evalNetAttr.set_Evaluator(streetsNetworkSource,
                    esriNetworkEdgeDirection.esriNEDAlongDigitized, (INetworkEvaluator)netFieldEval);
                    esriNetworkEdgeDirection.esriNEDAgainstDigitized, (INetworkEvaluator)
                    netFieldEval);
                netConstEval = new NetworkConstantEvaluatorClass();
                netConstEval.ConstantValue = 0;
                evalNetAttr.set_DefaultEvaluator(esriNetworkElementType.esriNETEdge,
                    (INetworkEvaluator)netConstEval);
                evalNetAttr.set_DefaultEvaluator(esriNetworkElementType.esriNETJunction,
                evalNetAttr.set_DefaultEvaluator(esriNetworkElementType.esriNETTurn,
                // Add the attribute to the array.
                attributeArray.Add(evalNetAttr);
                deNetworkDataset.Attributes = attributeArray;
                // Create a NetworkDirections object and populate its settings.
                INetworkDirections networkDirections = new NetworkDirectionsClass();
                networkDirections.DefaultOutputLengthUnits = esriNetworkAttributeUnits.esriNAUMiles;
                networkDirections.LengthAttributeName = "Length";
                //networkDirections.TimeAttributeName = "TravelTimeSeconds";
                //networkDirections.RoadClassAttributeName = "RoadClass";
                // Add the NetworkDirections object to the network dataset data element.
                deNetworkDataset.Directions = networkDirections;
                // Get the feature dataset extension and create the network dataset based on the data element.
                IFeatureDatasetExtensionContainer fdxContainer = (IFeatureDatasetExtensionContainer)
                    featureClass.FeatureDataset;
                IFeatureDatasetExtension featureDatasetExtension = fdxContainer.FindExtension
                    (esriDatasetType.esriDTNetworkDataset);
                IDatasetContainer2 datasetContainer2 = (IDatasetContainer2)featureDatasetExtension;
                IDEDataset deDataset = (IDEDataset)deNetworkDataset;
                INetworkDataset networkDataset = (INetworkDataset)datasetContainer2.CreateDataset
                    (deDataset);
                // Once the network dataset is created, build it.
                INetworkBuild networkBuild = (INetworkBuild)networkDataset;
                networkBuild.BuildNetwork(geoDataset.Extent);
            catch (Exception ex)
                //close
