Calculate point to point distance on a route (street network)
3674
08-04-2014 07:48 AM
MichaelLodes1
I have an amount of starting points and an amount of ending points lying on the lines of a street network.
Both point types have own feature classes.
Now I would like to filter out the ending points that lie a certain distance away from the starting points.
I spent now several days to find that out but meanwhile I am pretty desperate.
Can PLEASE somebody help me?
Best Regards,
Michael
DanPatterson_Retired
Did you rule out the Origin Destination Matrix?  from the help files "The OD cost matrix finds and measures the least-cost paths along the network from multiple origins to multiple destinations."
MichaelLodes1
Thank you very much for your answer.
I followed the instructions on the ArcGIS Help Site but I am not able to append multiple (origin and destination) locations with the "Add Locations" tool.
The workflow by creating new toolbar ("Network Analyst") and then creating "OD Cost Matrix" I can easily reproduce ..... load my origin and destination class into the OD Cost Matrix classes by right clicking into the Content Table onto "Origins" and "Destinations".
But I have to create a model in the model builder, so I need to do this with tools from the toolbox.
So I used at first the tool "Make OD Cost Layer Matrix". Then I have to use the tool "Add Locations".So at this point appears the problem that I cant load several classes (the origins and destinations classes).
In the end you have to use the "Solve" Tool to finish the process.
What am I doing wrong?
Sorry if I am too stupid but I find that this is really user unfriendly...
Creating a model is quite a bit different than your original question.
MattCrowder
Run the Add locations tool 2 times.  One time to load in your origins and another time to load in your destinations.
