ArcGIS Pro 2.5: “create network location tool” appears not to be available,
160
04-15-2020 12:11 PM
JamalNUMAN
Honored Contributor
I observed that the “create network location tool” is not available.
Is this by design?
This tool enables adding the stops by directly clicking on the map.
Tags (1)
MelindaMorang
Yes, this is by design.  In ArcGIS Pro, you can use the standard editing tools available on the Edit tab to create and modify Network Analyst inputs.
DanPatterson_Retired
MVP Esteemed Contributor
It appears you are coming to the Network Analyst after many version of ArcGIS Pro.
Perhaps, the tutorials will provide some background on the workflow available now and how things might differ from those in ArcMap
This is a link to the first tutorial
Tutorial: Closest facility—ArcGIS Pro | Documentation
Melinda Morang‌, Jay Sandhu
may have more targeted information on keystroke difference between the two platforms as they apply to the Network Analyst
MelindaMorang
JamalNUMAN
Honored Contributor
Thank you Dan and Melinda for the help. It works fine
I couldn’t figure out how to remove stops and routes without visiting their attribute table
MelindaMorang
Just select the Stop or Route you want to delete, and hit the Delete button on the Edit tab.
JamalNUMAN
Honored Contributor
Many thanks Melinda. That’s great.
