Allocated weighting for network location allocation
316
05-10-2018 03:34 AM
Thomasvan_Lanschot
Im trying to solve a Location-allocation problem using the network analyst tool. I have a series of facilities with a capacity and a series of demand points with an output value. I need to join demand to facility until they are 'full'.
I was looking to do this with the allocation weighting.
One issue i have in solving this is I cant use my own allocation weighting from my point layer. ARC creates a new demand point data set with a uniform value for all points.
Does anyone know how i might solve this issue
networkanalysis location allocation #arc desktop
Reply
JaySandhu
When you load your point layer as "demand" for a location-allocation layer, you can map in the field that contains your allocation weighting as "Weight". See the attached screen shot that maps the field POP2000 to the weight property.
Similarly you can map in the "Capacity" for the Facilities. Make sure to use the "Maximize Capacitated Coverage" problem type to solve with capacity.
Jay Sandhu
Reply
JaySandhu
Jay Sandhu
Reply
Thomasvan_Lanschot
Hi Jay, Thanks a lot.
Reply
