Can the topology rules be modified to check for node connections for line segments?
To check for proper connectivity for a street line data set I currently convert all lines to start and endpoints run a "near" function for a 25' distance and then summarize and sort the results from smallest to largest proximity. This finds errors where pseudo-pseudo nodes should be snapped to a four way intersection.
Hello Preston. Check out ArcGIS Data Reviewer's Find Dangles Check. This check is available in ArcMap's Data Reviewer or in ArcGIS Pro's Attribute Rules as Ready-to-Use rules.
https://pro.arcgis.com/en/pro-app/latest/help/data/validating-data/find-dangles.htm
I use this check all the time for street centerline data and utility network data where there's valid dangles but still need to check for proper connectivity.
