ArcGIS Navigator
1129
03-01-2017 09:26 AM
MatthewKauth2
Hi, Mark.
I've created another mmpk that I can view in Navigator. I can search for an address and drop a pin to calculate a route. The problem is I receive an error, "Can't calculate route".
I've attached the mmpk file as a reference.
Matt
Matt Kauth
GIS Analyst
Geospatial Software Development Team
55 E. Monroe St., Suite 3450, Chicago, Illinois 60603
P 312-201-7961 | C 708-227-0171 | F 312-220-0722
mkauth@patrickco.com<mailto:mkauth@patrickco.com> | www.patrickco.com
****Patrick Engineering Inc. Confidentiality Notice: The information contained in the above e-mail message or messages (which includes any attachments) may contain confidential, proprietary, or legally privileged information. It is intended only for the use of the person or entity to which it is addressed. If you are not the addressee any form of disclosure, copying, modification, distribution, or any action taken or omitted in reliance on the information is unauthorized. If you received this communication in error, please notify the sender immediately and delete it from your computer system network.****
MarkBockenhauer
Matt,
Are you able to successfully route with the source data in ArcGIS Pro?
I tried routing with the MMPK in Pro and received and error.
"ERROR 030024: Solve returned a failure.
The network dataset has no edge elements. It may be unbuilt.
Failed to execute (Solve)."
I suspect something may be a bit off with the source data, so make sure it works in Pro for routing, prior to creating the package.
Mark
