WinService extension error
1213
08-02-2019 10:17 AM
MikeSchonlau
I'm getting this error when I try to configure the WinService extension:
I am using a server name like subdomain.hostname.com. I've also tried it with private and public ip's, and with https:// in front. Any ideas what I'm doing wrong?
JohnGraham2
Hi Michael,
Try adding a Process counter instead for the services you want to monitor, such as ArcGISServer or ArcGISPortal. Maybe the subdomain is preventing the WinService extension script from accessing it.
Hope it helps,
John
JohnGraham2
Hi Michael,
Check that the target system can be monitored with the standard System counter type in ArcGIS Monitor before adding this extension. You might need to set Windows permissions to allow monitoring. The error above happens when the target system cannot be accessed to find the Services.
Hope it helps,
John
MikeSchonlau
Hi John
I do have a successful system counter for this server. However, I am not able to get the WinService counter to work using the server's hostname, public ip, nor private ip. Any other ideas?
JohnGraham2
Hi Michael,
Hope it helps,
John
MikeSchonlau
Thanks, John. I do have Process counters setup, so I will just use those to keep an eye on the ArcGIS Server and Portal processes.
