What is the next generation ArcGIS Monitor release?
3362
14
11-30-2021 10:38 AM
BillFox
MVP Notable Contributor
What is the next generation ArcGIS Monitor release and what is the migration workflow?
Amanda__Huber
MVP Regular Contributor
Hi @DerekLaw thanks for that, but asking if Monitor 10.8.1 is compatible with Enterprise 11?
DerekLaw
Esri Esteemed Contributor
Hi @Amanda__Huber.,
Sorry I mis-read your post.
> ... asking if Monitor 10.8.1 is compatible with Enterprise 11?
We haven't done any testing for this configuration. It might work, but is definitely not supported, nor being promoted by Esri.
Hope this helps,
DerekLaw
FYI - ArcGIS Monitor 2023 will be released on Feb 7, 2023.
Hope this helps,
JenniferReilly2
In order to go to ArcGIS Monitor 2023 from a previous installation, can one simply install the new files as an upgrade, or would one need to uninstall the previous installation and then install ArcGIS Monitor 2023?
DerekLaw
Hi @JenniferReilly2 ,
ArcGIS Monitor 2023 has a completely different architecture and internal framework compared to Monitor 10.8.1, because of this - there is no direct upgrade path. Sorry.
Please see the ArcGIS Monitor 2023 FAQ, Q5.
https://community.esri.com/t5/arcgis-monitor-documents/arcgis-monitor-2023-0-frequently-asked-questi...
Hope this helps,
