Query more than 1000 records from ArcGIS Monitor feature service
1636
07-27-2023 07:46 AM
ChrisTaylor2
I'm trying to set up a Dashboard (10.9.1 Portal) using the feature service from a Collection in Monitor. The specific element I'm configuring is to get a count of all of the instance saturation alerts over time, grouped by service name. However, I've noticed that the query is only returning 1000 records at a time - is there a way to change this? I'm not sure how to get at the service properties since the service is hosted by Monitor.
Chris
2 Solutions
GeoJosh
This is governed in ArcGIS Monitor Server by the Maximum Record Count setting (Administration > Server > Maximum Record Count).
However, this is set to 10,000 by default. If you haven't changed this setting, then I suspect the limitation is being imposed on the Dashboard side.
Josh
GeoJosh
Hey @ShaunLangley,
If you query the feature service outside of Arcade (i.e. using a REST client like Postman), do you see the same behavior? I suspect that the feature count is being limited by your client a.k.a. Arcade.
Josh
GeoJosh
Josh
ChrisTaylor2
Perfect, I should have thought to look there, thank you. I'll look into a possible limitation on the Dashboard side of things and comment back on this thread if I find anything.
Thanks again,
Chris
ShaunLangley
I stumbled on this post while researching my own problem.  I'm experiencing the same behavior, however my configuration is currently set to the default value.  My issue is documented here https://community.esri.com/t5/developers-questions/feature-count-limit-in-a-for-loop/td-p/1347324.
GeoJosh
Hey @ShaunLangley,
Josh
