Monitoring & Alerting % of Disk Usage
2000
03-21-2023 08:18 AM
SteveMcCarthy
We currently track % of disk usage with alerts Example:
Is there a way to track % of disk usage with alerts in Monitor 2023?  I can see the amount of GBs used on a disk but, unable to see % and setup an alert.
Tags (1)
DerekLaw
Esri Esteemed Contributor
Hi @SteveMcCarthy
Please try this workflow:
1. Login into ArcGIS Monitor > Monitoring tab
2. Under the Filter folders - select Storage
3. Select the storage device you want to set an alert on - this will display the overview metrics page for the storage device
4. Select the Metrics tab (in the upper right banner) - this will display the different properties of the storage device
5. Click the ellipsis button (the three dots) for the parameter you want to set the alert on, for example "Storage Capacity Used (GB)" > Edit alert rules
6. The Edit Alert Rules dialog should appear for the selected parameter and you should be able to set an alert
Hope this helps,
SteveMcCarthy
@DerekLaw Thanks for getting back to me so fast.
This give me the ability to set the alert to a set #GB, our disk drive sizes vary on our 50 servers
ArcGIS Monitor 10.8.1 Allows the following:
We set our alerts Warning at >75% and Critical >90%, this way I don't have to figure out these percentages and stay appropriate as we add or remove disk space.
VilnisKarklins
You could monitor Storage Capacity Available (GB) instead of Storage Capacity Used (GB)
SteveMcCarthy
Monitoring storage capacity available (GB) would work as long as I can use %, I have 50 servers with various size disks.  I just want to know when our disk are at 75% capacity warning and 90% capacity critical, we have had issues with large chunks of data filling up our drive space. A few years back we lost our production portal when some one decided to put 7 TB of LiDAR data on it.
EsriEvan
Hi @SteveMcCarthy - totally understand your point. We will address this immediately. It will go into 2023.1
