Monitor Server config-store relocation?
337
08-19-2025 09:13 AM
JeffMertzXcel
Related to post Solved: Does the ArcGIS Monitor SQLite DB for logs get com... - Esri Community
Is it safe to relocate the ArcGIS Monitor Server config store (and related sqlite databases) ?
Specifically, had a space issue due to the logs database under C:\Users\xyz\AppData\Local\ESRI\ArcGISMonitor\config-store-server\logs.
Our logs database was over 45 GB (plus another 16GB for the WAL) and filled up the C: drive (C: drive space is very limited and everything goes on F:). I could not even bring up the Administration/Logs page due to its size. Eventually, I went into the sqlite database and deleted several million rows of data. After starting Monitor Server, I was able to get into the Logs page and change the settings back to Warning Level and 45 days retention. Soon after, the space was reclaimed (due to auto vacuuming?) and the C: drive was happy.
So then, tinkering around, I stopped Monitor, edited the .env file under config-store-server directory and changed the CONFIG_STORE_PATH to the F: drive. I then copied all the config-store-server files to the new directory on F:. Upon starting Monitor Server, looks like the logs (and data) are being written to the new location. Best guess is that Monitor Server is reading the .env on C: but then storing everything on F: which is fine for this experiment.
It would be nice to relocate the entire Monitor config store out of AppData / off of C: drive - guess that's an enhancement request I need to post.
Anyone else out there experience something similar?
DerekLaw
Esri Esteemed Contributor
Hi @JeffMertzXcel,
Yes, it is possible to relocate the ArcGIS Monitor Server config store. And the workflow you shared in your post is the correct.
FYI general steps:
1. Stop the AM Server service.
2. Locate the .env file
(for Windows, C:\Program Files\ArcGIS\Monitor\Server\bin)
3. Edit the .env file with the new config store location (edit CONFIG_STORE_PATH)
4. Save the .env file.
5. Move the ArcGIS Monitor Server config store to the new location.
6. Restart the AM Server service.
Ensure that the AM Server service account has permissions to the new location.
Hope this helps,
DerekLaw
Hi @JeffMertzXcel,
FYI general steps:
Hope this helps,
