Installing ArcGIS Monitor with SQL Server DB
2129
6
03-25-2024 01:08 AM
ChiefMaster
Hi Folks,
Is there any way to install ArcGIS Monitor with a SQL Server database instead of PostgreSQL, which is recommended?
2 Solutions
ReeseFacendini
Esri Alum
Postgres is required to install ArcGIS Monitor. SQL Server is not supported as the back-end Database system.
DerekLaw
Esri Esteemed Contributor
Hi @ChiefMaster,
Just to elaborate on Reese's post: only PostgreSQL can be used as the database platform to install the ArcGIS Monitor repository. No other DBMS platforms are supported.
Hope this helps,
ReeseFacendini
Esri Alum
DerekLaw
Hi @ChiefMaster,
Hope this helps,
JoshuaBixby
MVP Esteemed Contributor
@DerekLaw, any plans to support anything different besides Postgres?
DerekLaw
Hi @JoshuaBixby,
> ... any plans to support anything different besides Postgres?
Not at this time.
Hope this helps,
JoshuaBixby
Thanks.  Yeah, it helps to know not to expect anything else in the near to mid term.
ChiefMaster
Thanks @ReeseFacendini  & @DerekLaw  for the response; it's clear to me, and I hope it will be supported in the near future because most governmental sector clients at ME do not put PostgreSQL as their first choice; they usually prefer SQL Server and Oracle.
