HTTP counters setting automation
1016
10-23-2020 08:42 AM
MatShop
I am new in using ArcGIS Monitor. I have to create http counters and alerts in an hundreds-of-arcgis-mapservices environment (dev, staging, preprod, prod). I need to automate this workflow, it can't be done manually.
l saw that there is an API but it seems that it is dedicated to explore log data.
I also had a look at extensions but it seems that it will help me in creating new counters types, not in automating existing counters type setting.
Is there a way to automate http counters settings in ArcGIS Monitor, rather than doing it manually ?
MatShop
Great news ! it is possible to automatically create a .cpj file, and then to import it following this documentation :
Import existing monitor services—ArcGIS Monitor | Documentation d’ArcGIS Enterprise
MattD
by Esri Contributor
It is not possible to automatically create the same HTTP counters for multiple deployments outside of editing the CPJ file. Importing the CPJ file will create a monitoring service with the same inputs as the previous monitoring service, so manual rewrites of the counters will still be necessary.
