How to Register ArcGIS Server with URL
292
03-20-2025 05:44 PM
DavidJantz
How can ArcGIS Server be registered using a web adaptor URL? It looks like in Monitor 2023, you could specify the URL used (https://doc.arcgis.com/en/monitor/2023.3/get-started/windows/register-arcgis-server.htm), but in 2024, that ability no longer exists (https://doc.arcgis.com/en/monitor/2024.0/get-started/windows/register-arcgis-server.htm).
DerekLaw
Esri Esteemed Contributor
Hi @DavidJantz,
> ... can ArcGIS Server be registered using a web adaptor URL ... in 2024, that ability no longer exists
This is expected because in ArcGIS Monitor 2024, we now require you to install AM Agent on the ArcGIS Server host. The AM Agent communicates locally with the GIS Server.
Hope this helps,
