How to refresh services into Monitor
721
08-19-2024 07:00 AM
MichaelBartlett
I notices some services are missing in arcgis monitor for my ArcGIS Servers,  And some services that have been deleted are still listed.  I am using 2023.3.1
I know when we add the Server, it pulls in all the services.
What is the process for refreshing these?  Can I manually add and delete them?
MichaelBartlett
Ok, Esri Support tacked my issue, and I figured out where to run the Observers.
Apparently there is a known issue if in the Server Admin Usage reports there is a report with all numeric values in it's name, it fails to update, so we deleted that usage report, and like Magic started working again.
Thanks Josh for your help.
GeoJosh
Hi @MichaelBartlett,
Services are automatically added and removed from ArcGIS Monitor by the ArcGIS Server Discover observer. Go to the ArcGIS Server component > Settings > Observers > Discover and try running it manually by clicking "Run Observer".
Josh
MichaelBartlett
Hmm.  Can you send a screen shot, I don't seem to be able to find that.  However, I do see I am getting a bunch of errors in the logs.  So that might be why it isn't refreshing.
Details
["New-CimSession : WinRM cannot process the request. The following error occurred while using Kerberos authentication:"]
Message
An error occurred running the observer
Resource
observers:54
MichaelBartlett
