How to get value from Check Service Observer
273
06-30-2025 05:22 PM
Timothy
Using the Check Service Observer can I record the matched regex value as the monitor metric?
e.g: Obtaining how many surveys have been submitted in last 7 days - Check Service Observer Settings
Interval
1 hour
Enabled
Yes
Request URL
https://<server>/server/rest/services/Hosted/survey123_64fc8266b5ec47388f40eac47f863f3a/FeatureServer/0/query
request_data
[ { "key": "where", "value": "<DateField> >= CURRENT_TIMESTAMP -+ INTERVAL '7' DAY" }, { "key": "format", "value": "json" }, { "key": "returnIdsOnly", "value": "true" } ]
Request Method
get
Response Check
\d+
I would prefer to use 'returnCountOnly' and then separately be able to ingest a value from the FC attributes for other alerting purposes.
EsriEvan
Hi @Timothy ,
This is great use case - however I don't believe this is possible in the latest release (2025.0).
Can I ask the use case behind counting the number of features in a layer? I think I can guess but would like to understand your specific case so we can add details!
I suspect the general enhancement would be to parse the JSON response and access a specific value from there (in your case, the count property). I will take this back to the team but would also encourage you to submit an enhancement request through support, if possible.
Thanks!
Timothy
Hi @EsriEvan,
  1.  A data workflow updates a imagery service and it isn't actively monitored but new imagery is expected to be added weekly.
  2. A single FC row value needs to stay above a specific level.
  3. Amount of FC features that haven't been edit in X days.
ArcGIS Monitor to provide email alerts and metrics across time.
Cheers
Tim
