Get notified if metrics are not collected
86
Tuesday
Yanu
Hey,
is it possible to set-up an alert or notification to be sent out when metrics for ArcGIS Server are not being  collected?
Regards,
Yanu
DerekLaw
Esri Esteemed Contributor
Hi @Yanu,
I believe you can configure a notification for when an observer stops collecting metrics. Please create a new Custom Notification with this event subscription:
Resource Type is Observers and the Operations is updated.
where Component ID is the ID value of your ArcGIS Server component.
Hope this helps,
DerekLaw
Hi @Yanu,
Hope this helps,
Yanu
Thank you so much!
