FeatureServer Subtype Not Showing Up
1132
08-09-2023 09:03 AM
BenRomlein
I've added my ArcGIS Server and all of the services are showing up, but only as Map Server subtypes.
I've noticed that connections made through the FeatureServer URL are not generating metrics.
I understand Hosted Feature Services are not yet supported.
The data behind the Feature Services I want to add is stored in an enterprise geodatabase and the services are published to the root services directory.
Is there a way to add these services to Monitor?
Thanks!
Ben
EDIT: I should add, I'm using Monitor 2023.2 and my Servers are 11.1 and 10.9.1
AndrewSakowicz
@BenRomlein .  Thank you for this feedback.  Can you provide more specifics of your case?  Is it querying a feature service layer? I asked, because we successfully tested querying  a feature service layer (query count was incremented as expected). @EsriEvan
AndrewSakowicz
BenRomlein
Andrew,
Thanks for your reply. Upon further testing, you're right--requests to the Feature Server are being monitored and recorded.
The interface has a filtering option for Feature Server subtypes that returned no components:
This and the delay between requests to the service being sent and being displayed in monitor made me think it was only logging requests to the Map Server URL.
But it looks like the component is properly logging requests to the service whether the connection is through the Feature Server or the Map Server URL.
Thanks again for helping me walk through it!
Ben
