Exporting analysis in Monitor 2024.1
463
03-19-2025 08:35 AM
ChrisSchofield
Hi all
Just getting my head into Monitor and I've created a couple of 'decent' analysis sets that I'd like to export into prod.
According to the docs, exporting them should be an option in 2024.1, but when I click the ellipses I do not get that option:
Am I missing something? (other than the export function obviously 😁)
Thanks in advance
StevenBeothy
Are you certain you are on 2024.1 and not 2024.0.1, also check if you are logged in as an Admin or Manager user?
You can check both by clicking on your profile on the top right of the AGM interface.
My AGM 2024.1 Analysis Page shows "Export analysis" when I click the More Options ... on the Analysis View.
Also to Import Analysis views you should be able to see "Import Analysis" from Create analysis dropdown menu.
StevenBeothy
ChrisSchofield
Maybe I should wear my glasses more....I was indeed on 2024.0.1 not 2024.1.
Installed over the top and now the option is there......thanks for that 😁
