Early Version of ArcGIS Server
527
01-11-2018 01:31 PM
Juan_ManuelAngel
Hi, do you know if i a can add a ArcGIS Server 10.4 to the ArcGIS Monitor or it just can be ArcGIS Server 10.6 , Thank you for the help.
GarrettGraham
Hi Walter and Juan - ArcGIS Monitor 10.6 is compatible with ArcGIS 10.2 and newer, per the General FAQ doc. In Juan's case, using ArcGIS Monitor 10.6 will connect to ArcGIS Server 10.4 just fine.
by Anonymous User
Not applicable
System Monitor v3 supports ArcGIS Server 10.1 and higher, therefore I would expect ArcGIS Monitor to support (at least) 10.1 and higher.
[...ArcGIS Server monitoring requires ArcGIS Server version 10.1 or higher...]
 Garrett Graham‌, could you confirm it?
GarrettGraham
