Automate and run System Log Parser for IIS as regular scheduled job
902
07-17-2019 11:55 AM
JohnHu
I like to get help on how to automate and run System Log Parser for IIS as a Standalone tool.  If you have already done this,  please help and share.    Thanks.
JohnGraham2
Hi John,
When you open the SystemLogsGUI application, click on Help button and expand section: Using System Log Parser Tool > Using Command Line. Commands can be automated by making a script. If you need more help with System Log Parser, contact Esri Professional Services for consulting.
Best Regards,
John
ChugachElectric
John -
I am also trying to script the running of the System Log Parser, but my help file contents are largely empty. So although I can see the header you refer to ("Using Command Line") there is nothing in that topic, or in any of the other headers. Do these help docs live anywhere else? If not, can you post a copy here?
Jena
ChugachElectric
I should add, I have run "slp.exe -h" to get the command line usage, but was wondering if there was additional data in the actual help doc.
