ArcGIS Monitor Server Windows Services Will Not Run
2508
03-13-2019 01:56 PM
rbae
Brand new install, Windows Server 2016, MongoDB 4.0.
After a few seconds, the Windows service stops running.  I have the following log from the Event Viewer:
Child process [7076 - C:\ArcGIS Monitor\Server\node.exe  --harmony "C:\ArcGIS Monitor\Server\node_modules\node-windows\lib\wrapper.js" --file "C:\ArcGIS Monitor\Server\app.js" --log "ArcGIS Monitor Server wrapper" --grow 0.25 --wait 1 --maxrestarts 3 --abortonerror n] finished with 1
Any suggestions on what might be wrong?
-Ryan
JohnGraham2
Hi Ryan,
Good to hear it's working. Yes, a drive path mismatch between the ArcGIS Monitor\Server and location of the data will lead to this error.
Best Regards,
John
rbae
I re-ran the post install, and the only thing that I did differently was to move the location of the data from the D drive to the C drive where the software was installed.
Everything worked great after that...
JohnGraham2
Hi Ryan,
Best Regards,
John
DavidRunneals2
Hmmm... Getting the same error message:
Child process [11048 - E:\ArcGIS Monitor\Server\node.exe  --harmony "E:\ArcGIS Monitor\Server\node_modules\node-windows\lib\wrapper.js" --file "E:\ArcGIS Monitor\Server\app.js" --log "ArcGIS Monitor Server wrapper" --grow 0.25 --wait 1 --maxrestarts 3 --abortonerror n] finished with 1
And the Mongo data and log folders are at E:\ArcGIS Monitor\Mongo\
I'm at a loss... It was working and then it just stopped working.
VilnisKarklins
did you manage to fix it? If yes, what was the solution ?
