ArcGIS Monitor: "item not running or behind schedule"
2327
6
06-01-2020 12:08 PM
TristanForward1
The System Log Parser extension keeps reporting  "item not running or behind schedule".
They are all set to run hourly and we have already run the stagger collection times bat file yet the issue persists.
Stop Collection and Start was also tried but no luck
Anyone have any luck the the System Parser?
by Anonymous User
Not applicable
Did it ever work after the initial configuration and clicking TEST?  Or did it work and then it stopped?  Try running SLP manually by clicking on the Systems Logs GUI executable in the ArcGIS Monitor /bin folder.
BobBarker
I'm having a similar problem.  Is there a resolution?  Manually SLP works, but if I try to test the task the Test button spinny never stops.
AndrewSakowicz
Please clarify which extension you are using, SLP for IIS, ELB, Azure, ArcGIS?
BobBarker
For ArcGIS.
AndrewSakowicz
Bob, the latest version of ArcGIS Monitor includes ArcGIS Server info - this extension is not required anymore (removed from the gallery).  Please see ArcGIS Monitor for these new features, e.g.
BobBarker
Thanks, I'll update Server Monitor.
