ArcGIS Monitor Notification Email
4749
17
03-23-2023 07:50 AM
SteveMcCarthy
Where would you go to update name field so it shows the Name associated with the ID?  Is it possible to change what attributes are in the notification?
DerekLaw
Esri Esteemed Contributor
Hi @Galada_321,
No, there are no changes to email notifications in the forthcoming Monitor 2023.2 release. The 2023.2 release will be a minor update with a focus on database partitioning.
Hope this helps,
LisaDong
Esri Alum
Heads up everyone,
For your reference, here are the two enhancements that helps with this behavior:
  1. ENH-000159627 : For email notifications in ArcGIS Monitor 2023, provide equivalent functionality to ArcGIS Monitor 10.8.1.
    • Status: In Product Plan
    • In ArcGIS Monitor 2023.x, the client is asking for Metric Name to be populated instead of NA, along with STATUS, ALERT RULE and ALERT VALUE information in email notifications to restore equivalency with ArcGIS Monitor 10.8.1.
  2. ENH-000153088 : Ability to create a summary email template within ArcGIS Monitor.
    • Request to receive periodic summary of issues via email templates.
TimoT
I'm still very keen on ENH-000159627. I was hoping it being in product plan for over a year would have some further news by now.
How is everyone else managing their email alert notifications?
Have you just accepted that the name is NA? Or have you created dozens of custom notifications for each metric or component instead of using collections?
Timo
JackHardwick4
Our organization was also a little bummed with the limited email notification functionality. In the meantime, I thought I'd share a tiny workaround to this for everyone else.
The notification name is included as the email subject line, so I've created around 5 different notifications so far with different names so I can tell at a glance in my inbox what has happened.
In my email, I see the following:
100% not ideal but at least I can at a glance know what the alert is for. Probably only good for smaller deployments like mine, unless you're okay with managing a bunch of these notifications. Hopefully we see this functionality fleshed out a bit in future updates. I'll probably keep doing it this way in the meantime..
TimLehn
I agree with most here that this needs to be addressed.   Notification are pretty much useless unless you set up a notification for every alert possibility.  For me minimum is name,  but really feel it should be configurable for name, State, opened at, Closed at, duration, Type, Subtype, and description.  Comments might also be helpful but i could see where that might be out of scope.
DerekLaw
All,
FYI, there are some enhancements to email notifications in the ArcGIS Monitor 2024.1 release. Please see the What's New in ArcGIS Monitor 2024.1 release blog.
Hope this helps,
Amanda__Huber
MVP Regular Contributor
This is incredible! Thanks so much @DerekLaw and team for implementing this.
We're very excited to test it out.
Best,
Amanda
SteveMcCarthy
All of these enhancement look very helpful:
  • ArcGIS Monitor can register and collect metrics on the ArcGIS Data Store (relational)
  • Export/import of analysis views
  • New Table and Rich text elements in analysis views
  • New Check-Service user configured observer
  • Improved email notifications
  • Support for the ArcGIS Web Adaptor (available with ArcGIS Enterprise 11.4)
