ArcGIS Monitor Excel Report does not generate report
1196
05-26-2023 01:27 PM
EdnaKanazawa
We are generating the report using ArcGIS Monitor Excel Report, but it is generating the error below
2023-05-26 16:52:58.776511 service,Request Response Time Avg,svcRTAvg
'features'
File "ExcelReport.py", line 11, in main
File "modules\report_builder.py", line 24, in __init__
File "modules\Wkb\wkb_builder.py", line 36, in __init__
File "modules\AGM_API\collection.py", line 154, in metric_stats_by_name
KeyError: 'features'
None
Tags (1)
AndrewSakowicz
@EdnaKanazawa  Do you have arcgis server service in the collection specified in the SampleConfig.json?  Note, you can remove types as needed, see below
EdnaKanazawa
Yes, I have one portal, server and host @AndrewSakowicz
AndrewSakowicz
Thanks @EdnaKanazawa Can you verify that you have this metric (request response time) in one of you your services?  Also, can you test removing "service" from types.  If this does not provide clues, l'll contact you directly to troubleshoot this.
