ArcGIS Monitor 2025.1: Service metrics not being collected
2897
24
11-21-2025 06:54 AM
ReeseFacendini_MadCo
After upgrading to ArcGIS Monitor 2025.1, the service level metrics are no longer showing for any published service (hosted, map, image, etc.). I checked the observer logs and there are pages of warning logs saying "failed to determine ArcGIS Server license expiration". My ArcGIS Server license is permanent, so technically there isn't an expiration date.
Anyone else seeing this issue?
DerekLaw
Esri Esteemed Contributor
All,
We have a fix for BUG-000181273 and we will be releasing the ArcGIS Monitor 2025.1.1 patch on Dec 11, 2025 - next week. It is only for ArcGIS Monitor Agent.
Thank you for your patience and apologies again for the inconvenience.
AdministratörHolmen
We are seeing this exact same issue, have tried many a remedy at this point and nothing seems to be making it work. I have tried thus far:
Clean out the statistics folder for the server
Remove all usage reports
Clean install of monitor server + agents
Checked ports
Checked communication between server
Tried this: https://support.esri.com/en-us/knowledge-base/problem-arcgis-monitor-is-unable-to-receive-metrics-fr...
Editing my reply:
It absolutely seems to relate to licenses that never expire, because I have observers on our ArcGIS Portal (11.5) as well which has expiring licenses and those work like a charm. I am guessing this is a bug that needs patching?
DerekLaw
@ReeseFacendini_MadCo - Thanks for opening a case with Esri Tech Support on this issue.
@AdministratörHolmen - If you haven't already, can you please open a case with Esri Tech Support?
We are actively investigating this issue, but we're unsure if this has to do with the permanent ArcGIS Server license file or something else.
MikaelJ
When we can expect this to be patched? This breaks all of the monitoring in my deployment.
DerekLaw
Hi @MikaelJ,
Please see my latest post at the end of this thread.
As far as we're aware, this issue only causes data to not be collected from ArcGIS Server components. It does not affect other components. If you are seeing something else, please contact Esri Tech Support so they can investigate further.
Hope this helps,
royceSimpson1
+1 on this issue.  Will monitor this thread for updates.
AdministratörHolmen
@DerekLaw I have submitted a ticket, but as I am based in Sweden my cases go directly to ESRI sweden first and I have to ask them to send it to you guys, hopefully it can happen relatively soon.
KoltWright
I’m experiencing the same issue and submitted a ticket this morning. One thing I noticed is that the licensing inside ArcGIS Monitor still shows as version 2025.0, even though all of the new 2025.1 features are available. I’m not sure if this is because it’s still using the same licensing file or if something else is causing the mismatch.
royceSimpson1
This is interesting.  I used my existing 2025.0.x license file as well, and am experiencing the same issue.  If anyone grabbed a new license file and their stuff is working, please post here.
AdministratörHolmen
I grabbed a new file because we were still in 2024.x so mine is as 2025.1 as it can be I guess. However, it does say 25.0 in the license tab on the server, screenshot attached. So it should not be related to license, as my monitor is not working either.
